A
Anonymous
Guest
Hi,
I've been away from the woodworking scene for a while - and it seems you're all here now. Hi again - hope you're all doing fine!
I've just been given a task to make a set of double doors for a dyno-room (rolling road for motorbikes) which will be at the bottom of my brother's garden - lucky neighbours! He will be soundproofing the walls and ceiling but I've got the task of making the doors.
My plan was to construct the doors from a hardwood frame and MDF facing back and front. I can then sandwich soundproofing insulation in the cavity, and perhaps a membrane inside each MDF sheet. I was going to step the doors on both sides - obviously where the two doors meet, but also on the hinge side to allow two more surfaces to apply a neoprene tape seal to. The frame will need to be stepped as well.
Checking down at my local builders' merchant it seems all you can get hold of is meranti. This is not something I have worked with before, but I have heard it describes as quite a light density timber. If this is the case I am wondering whether a cheaper softwood might be a better option from the soundproofing point of view.
Does anyone have any suggestions about the best materials to use?
Thanks,
Phil (and his brother's neighbours!!)
Thanks,
