Evening all,
Now that I've the chuck off (at last) I spent a few hours today stripping down the machine. Aside from the weight of the thing it wasn't too tricky - with the exception of a few bearings, see below. Many of the bolts were reminiscent of Goldilocks, i.e. someone's been messing with it, and few were matching. These are easily resolved, so I'm not too bothered about that. Anyway, here's the results so far:
- a homemade, wonky belt cover holder :roll: This will need replacing along with the belt cover, which is an abomination made out of aluminium
- a couple of off-centre supporting brackets. I don't think it matters that these are a right mess as the various brackets bolt to it ok
- Swarf/debris!
- And now the quill. This had an unusual section towards the chuck end. It appeared that there was an insert, so I loosened the grub screw and removed it. Its face has been very poorly machined and will need addressing.
- I removed the bearings on the quill that I could. I think the upper one should be held in position via a grub screw: there wasn't one! It came off the quill easily. As did the middle (open) bearing. But the one at the bottom is fixed. I'm not sure how best to remove this bearing. Like the upper one it is not smooth and has some play.
- The bearings that hold the shaft in position in the top of the frame are much larger. There are 2: one above the other with some sort of bushing in-between. Unlike the quill bearings (above) these feel lovely and smooth. Through my own ignorance I've not attempted to remove them.
So in terms of importance I want to (1) remove the lower bearing from the quill, but don't know how best to - any ideas? (2) sort out that poor machining of the lower quill's face. I don't have a lathe and it's been years since I used one, and don't fancy spending £££££ on getting a local company to machine it for me. Is there a section of the forum where I could enquire if anyone local (I live in Bristol) would be able to do this for me?
Phill
- Swarf/debris!
Phill
