Strengthening back panel?
azk404
24 Dec 2020
London
I have built some box shelves that will be hooked to the walls with these - https://www.locksonline.com/Koala-Concealed-Wall-Hanging-Bracket-100mm-x-43mm-6692.html - so as these will be screwing partially into the 12mm ply back panel I would like to strengthen the hold. The main shelf is made from 18mm ply.
As of now its dadoed into the back with a slight lip to conceal the bracket with no nails or screws.
I know want to screw from the top, bottom or sides as these will be seen.
Any other suggestions? Corner brackets? or is it as simple as some small screws around the perimeter of the back?
I have attached a couple of heavy backless plywood shelving units to walls using a hidden French cleat system.
