Straight Edge Cutting Guides
wizer
3 Mar 2005
Hi
As I am ordering from Axminster I thought I would get myself a cutting guide for my Circular Saw. I need it for cutting sheet material. Axminster have about 3 varying brands, am not sure what the main differences are. Can anyone recomend a good cutting guide? I would prolly go for about 1.2/1.5m
johnelliott
16 Apr 2003
Near Swindon, Wiltshire
Before I went over to Festool, I used to use a Trend clamp guide which I found to be very good. If I was buying another I would get a longer one, maybe about 1.5mtr so as to have more run on/run off on a 1.22mtr cross cut
Noel
Moderator
Staff member
Moderator
7 Aug 2003
I've had a couple of the Perform 1270mm guide clamps for a few years and no problems. They clamp well, don't flex and far better value than the the Trend types. Prehaps Trend have slightly better cam mechs but at twice the price can't see much advantage.
Noel
andrewm
30 Oct 2003
Cambridge, UK
I have the Axminster guides. Fine when only using one guide but too much give when two are clamped together to give a perfectly straight cut. I tend to find that I need to support the join with a piece of scrap clamped to the board I am cutting. Will replace the whole lot with a Festool when I can afford it.
I have been looking for a good deal on the Festool and notice that Axminster have the Festool in their Spring Savers flyer. Reduced in price by the princely sum of 90p :-(
Andrew
Chris Knight
14 Jan 2004
SE London - NW Kent
It's a bit late now if you've bought the Perform but don't forget the straight piece of wood glued to MDF which you then cut with the saw so that you have a guide which only has to be placed on your cut line to give you perfect registration. With the Clamp 'n Guide type thing you have to allow for the offset of the saw base.
Before I got my Festool saw, I sometimes needed an ultra straight and clean edge and for this I used the sort of guide I mention except that I used a commercial steel straightedge, screwed to MDF and then my router with a spiral cutter to trim the edge.
Pete W
31 Jan 2004
London
Sorry I've just seen this.
I bought a few of the Perform guides and they're fine, but there's a thing to watch for. On my Perform guides, the clamp operates with a sideways motion and it's easy to pull/push your guide out of square when you apply the pressure.
The Trend guides use a vertical clamping mechanism which doesn't have this problem.
Not a deal-breaker but something to be careful about when you use them.
A
Anonymous
Guest
Axminster do a trend copy or should i say clone cheaper than the trend ones but a little more expensive than the perform ones.
Alf
22 Oct 2003
Up the proverbial creek
Yep, they're like the Rutlands ones. Not great, it has to be said. I think the Perform ones are probably better as an out-and-out straight edge.
Cheers, Alf
