Hi UKTony,
They look good, although I can't imagine the dubious looking one standing proud from the neck of my bottle of single malt! :shock:
Tony & Gary,
When I started turning I, too, found sanding tedious and time consuming, even when I improved and produced a reasonably good finish from the tools. Don't know whether you use the method but I turned (!) to power sanding - using a rubber pad mounted in an electric drill, sanding discs attached with velcro, very easy to work through the grits, taking seconds to sand rather than minutes (or longer when I started!
). The pads and discs are generally available. The Skilton brand is probably reckoned to be the best - got mine from Axminster.
Also had problems with finishing in the early days (not that I claim to be an expert now) particularly ending up with "rings" of built-up polish on large faceplate turnings, no matter what polish I used. Tried 'em all, with slow and fast speeds, light and heavy pressure, keeping the cloth moving across, but invariable on close examination still found those damned rings! :evil: My preferred method now for small faceplate work, and most spindle work, is one, sometimes two if necessary, coats of cellulose sanding sealer (I use cellulose for its quick drying time), each coat burnished with Chestnut burnishing cream. Then a polish-up with Black Bison wax provides the gloss and an excellent finish. This whole process I do on the lathe. For larger work I tend to power sand to 400grit, hand sand with the piece still spinning on the lathe to 500 & 600 grits, then, on the bench, apply a finishing oil, flattening off between coats with webrax or 0000 wire wool, using as many coats as I want to build up the required finish.
Above seems to work for me, and no "rings"
- so, for what it's worth........... But, as I said, I am not an expert. :wink:
Happy Christmas.
Cheers,
Trev.
