I've gone over the very helpful post from Ian Parkin, and I've seen a couple of threads on the forums here but I'm still not able to get this darned thing set up quite right.
The infeed table seems to be ok - and also doesn't really appear to have any way to adjust it.
The outfeed table on the other hand... well, I've tried to get the leading edge of the table even with the blades and then raise the back of the table to be on the same plane as the infeed table. When I do this though, it messes up my first adjustments. I have to be missing something, since right now it fees like I have to adjust all 4 points at the same time, have the outfeed table both up and down simultaneously, and have a pair of straight edges along the beds and a couple of spirit levels across 'em.
On the outfeed table there are 4 places you can adjust. On the back side of the table there are two bolts that you loosen to allow you to make some adjustments on that side of the table. On the near side of the table there's a big set screw as well as bolt that can be adjusted.
The set screw is the only one that is easy to adjust while the bed is down.
Here's a picture - anyone have any tips?
#1 and #2 are the bolts on the back side
#3 is the set screw
#4 is a bolt
#3 is the set screw
#4 is a bolt
