startrite max depth of cut??
kityuser
12 Jan 2003
my 351E (sick at the moment :( ) has a claimed "height under guides" of 300mm
from people`s general experience, what is the max depth of cut for a medium sized machine when cutting a hardwood? (bearing in mind that the machine has a 1HP motor)
regards
steve
A
Anonymous
Guest
300mm?? I am jealous. Mine only manges about 160mm which is limiting when resawing stock :(
Tony
Chris Knight
14 Jan 2004
SE London - NW Kent
Steve,
Most small machines come in at around 7 inches. I would love 12 inches like yours, although I think that a 1hp motor might strugge to cut that in hardwood.
kityuser
12 Jan 2003
I have`nt actually measured it on the saw but:
http://www.startrite.co.uk/bandsaw_351e.html
I`m not mis-reading this am i?
has anyone managed to sucessfully resaw stock > 150mm ?
by the way that wasn`t a gloat, but come to think of it maybe it was a small one 8)
steve
A
Anonymous
Guest
Hi Steve
No you are not misreading it - Height under guides 300mm :evil:
I have resawn 155mm stock quite often and found the Dure Edge blade absolutely essential for this!
So far I have resawn 150-155mm Oak, Ash, Mahogany, Meranti, Pine and Beech without any problems.
My Charnwood W720 has a 550W motor which is about 3/4hp
CHeers
Tony
PS I did notice the gloat
kityuser
12 Jan 2003
thanks tony, just the reply I was looking for :D (another kity user comes to save the day 8) 8) 8) )
I am using a duredge blade (alot cheaper than I thought) which is the max thickness my saw will take (3/4" 3 teeth - per - inch)
It`s just that on the board where the belt finally snapped, the saw was starting to struggle and I was worried that i was overloading it (very slow feed rate). It looks like from what you said that I was just seeing an early symptom of the brive belt failing. (fingers crossed)
what do you recon:
https://www.ukworkshop.co.uk/gallery/det ... age_id=265
am I going to struggle with some of these??? :?
is the solution just to slow down the feed rate, or take them to the yard i used to work at to resaw them on a bigger saw.
steve
kityuser
12 Jan 2003
hum, some of them are getting close to the max depth your saw can cut :shock:
you sure it`ll handle beech at that thickness? (the widest one is a wacking 280mm wide...........................280mm :shock:
you come get it, resaw it, bring it back and we`ll see 8)
steve
