Lons
I love my old 352 bandsaw with one niggle that's driving me nuts. The previous owner, dear friend that he was bless him was very careless to gouge the table quite badly, heaven knows what he did to his blades. :roll:
It sticks out like a sore thumb and though I've stripped it out today and temporarily filled the damage with steel weld stuff, ideally I want to alter it so I can fit removable inserts and there are only two ways I can see of doing that.
1). Cut out a square section maybe 40x 40mm of the shaped recessed part, glue or mechanically fix a support plate shaped to match the recess and make drop in inserts 40 x 40 x 5mm.
2). Cut out the whole of the shaped recess and mechanically fix a support plate, probably alloy to the 6 sided part under the table (support plate might need to be two part as the table splits), then make thick inserts the full shape. I could drill and tap the insert and support plate to take a countersunk machine screw to hold it down.
I can't work out why that recess is there in the first place. Any ideas other than those would be gratefully received and considered.
Tables are laid on the bench so not aligned before one of you points that out btw.
cheers
Bob
cheers
Bob
