Stanley no77 - help please
Saint Simon
19 Feb 2009
North London
Can anyone out there please offer me any advice on the sharpening and use of the Stanley dowel machine. I'm not having much luck with mine and wonder if there are any hints and wrinkles people could offer.
thanks
Simon
thanks
Simon
Try an American forum or list; those are rather rare over here.
BugBear
Hello Simon,
I use mine a fair amount and when they are sharp and set up correctly they are a pleasure to use.
When I sharpen mine I use a fine needle type file and try to keep a single bevel as near as possible to the original profile.
When the blade is fitted it is just a case of adjusting it back or forth to suit the timber being cut and the size you require to the nearest cutter block you are using.
Make sure you cut the square stock only 1/8" bigger than the size you need.
If you need a copy of the original instruction booklet or a photo of a new blade let me know.
Merlin
Hello Simon,
Here's a few photos of the cutter and the booklet.
Cheers, Merlin
    126.4 KB
    114 KB
    126.7 KB
    127.4 KB
