ZippityNZ
Yesterday, when buying a couple of second-hand hand planes, I was given a small plane that was caked in years of dust and grime.
The small plane was missing its iron cap and iron, but that was no big deal, as I just wanted to clean and restore it.
After dismantling and cleaning the plane, I noticed that it had no manufacturers name or model number cast on it. The only identification marks that I could find was "STANLEY" on the Lateral Adjusting Lever and the letter "B" on the back of the Lever cap.
The plane's sole measures 7 3/32" (not counting the tote overlap), the brass bolt nuts are solid and the low knob and tote appear to be Rosewood.
I do not believe that the Frog Screws and Adjusting Nut are the originals. The Frog Screws appear to be too long as each was sitting/packed on 3 washers, and the Adjusting Nut appears to be steel or something else.
There is no adjusting screw on the Frog.
At this stage, I am unable to place a year or type against this plane.
Can anyone ID this plane from the attached photographs?
