Stain, sanding grit, raising grain etc
Rorton
22 Mar 2019
Stoke on Trent
Probably over thinking this but here goes.
looking to add dark stain to some oak, doing some reading, it’s suggested just to sand to 120 grit and then stain. Also suggests raising the grain with a wet rag.
once that’s done, I apply stain, but haven’t yet addressed the raised grain and sanding that to make smooth again, so at which point would you do that.
If you sand after stain won’t that remove the stain. Or just a quick tickle with 240 grit
wanted to make everything as smooth as possible
You may have to wet then sand several times before the grain stops coming up. If you are going to use a water stain add a drop of fairy liquid to the stain, this will break down the surface tension and allow the stain to sink right down into the grain.
