nickds1
Wealden are just a few miles away from me. Used them for many many years. Excellent people.
I hope the moderators don’t delete my post for being ‘political’ this forum is becoming very woke IMO unfortunately.
Not sure I've seen anything really political there.I hope the moderators don’t delete my post for being ‘political’ this forum is becoming very woke IMO unfortunately.
You need to be a little careful buying these, as a lot of spiral bits are metric shanks, rather than imperial. Buying a metric bit / imperial shank isn't always straightforward, and they can be on the short side as they're often intended more for CNC applications than hand held routers. Wealden tool do them, though if you want a longer length you need to go to an 8mm shank.
aggressive / enthusiastic, and not bothering with dust extraction as they were really keen to get started.
Fits Katsu? Same fitting | size as Makita? Anyone know?If you search for makita trimmer collet on ebay or google, you'll see a set of 4 for 8 quid! They have a 3/8, 6mm, 1/4", 8mm
SP10174814 Collet Chuck Set 3/8" 1/4" 6MM 8MM Fits Katsu 101748 Trimmer : Amazon.co.uk: DIY & Tools
Free delivery and returns on all eligible orders. Shop SP10174814 Collet Chuck Set 3/8" 1/4" 6MM 8MM Fits Katsu 101748 Trimmer.www.amazon.co.uk
The spirals go up and do pull material up but slso throws out sideways. In my case the expelled material oacked into the edges when the guide bush got to the end of the jig slot so needs extraction. The upcut bit is partly about material ejection, but also the actual cutting action for when you are machining.... so you can decide on upcut so the bottom surface is best, downcut so the top face is best, or ( i think its ) compacting, which does both up and down, so you get good cuts on both faces of sheet materialMis-titled then? Upcut? Surely that should clear shavings upwards? Or is it simply getting caught up in the router base?
Neither are 1/2" and 12 mm, but the 12 mm will be fine in a 1/2" collet if you use a 1/2" K&S round brass tube, and cut a split in it. The split is so that the 12 mm bit will fit inside, and the collet can be tightened properly. The brass tubes are available from model hobby stores.Collets are machined to a precise measurement, 6mm and 1/4 (6.35mm) are not interchangable so check the sizes and get the right collets.
Register today and take advantage of membership benefits.
