Except for fully enclosed thicknessers, Square blocks were banned years ago, as they would drag you're fingers
and hand in and keep chopping away.
The Whitehill safety block, though much better, will take very large chunks of you because the cutter is usually arranged
above the block as well as the cutter projection, and so has full access to material or fingers.
The limiters, as the term implies, limits the amount of cut each revolution can take but as someone said in an earlier
post, at 3,500 rpm that's many, many nibbles a second.
As the amount of "bite" has been limited, so has the potential to snatch or grab of a workpiece and the operator be out of control.
A very good and simple way to "damage control" in the event of contact with the business end of a spindle moulder
Regards Rodders
