Spindle blanks
SteveF
16 Sep 2013
Maidstone
i am not the happiest making goblets
so the question is..what to do with them
i have a fairly large collection of blanks about 12" x 3" x 3"
it is the usual walnut oak purple heart sort of stuff
my main hobby is either pens..i have loads of pen blanks too..so no point chopping them up
and bowls is my other passion..so is it easy to glue cut prepare the blanks into bowls?
where do you start ?
or should i just sell em all and buy bowl blanks?
or what else can i do with them please?
i thought about a few tree decorations but there is a limit
this is just a hobby so not looking to make profit items
Steve
Have you thought of some threaded boxes. They would make great gifts. Endless options to chose from, but here is one. http://youtu.be/ItA3Kr71OI8
Failing that, segmented bowls are an option- as easy to prepare as cutting accurately and planing to a perfect fit. The ease (and cost) of that is largely dependant on the machinery available.
Keep them to one side the more turning you do the more ideas will turn up (Pun intended :lol: ). I don't do much spindle turning but always have some blanks for anything like candle stick, fruit etc
I make dozens of goblets a year, pity you don't live closer LOL. If they are all straight edged you could glue up for bowls, Maybe, with the different types of wood some basic segmented type ones? Odd, I am far more likely to cut bowl sized blanks down to make goblets. All different aren't we?
SteveF":1ouoiwiq said:
woodfarmer":1ouoiwiq said:
Glue 4 together side by side, make a really useful sized bowl.
would 4 look ok or do i need 4 and split 1 down?
Steve
12 inches long, 3 inches thick.. 4x3 = 12 so a 12 inch square blank.. give or take a sawcut
Steve
i thought may look better if "uniform" so i had matching colours on outside
so would need 3 x3 & 2 x 1 1\2
Steve
Just a thought- a bowl blank is cut from the tree so that the end grain is on the sides of the bowl, not the bottom.
So the glued pieces need to be glued so that the end grain from the spindle wood will end up on the sides of the bowl.
If you can understand what I mean.
Brian
Brian
i am confused
if i glue the blanks side by side then the end grain will be at the sides
a bowl blank is the inside \ outside is straight grain \ cross grain
am i being thick ?
we are talking about using the blanks \ spindles with end grains on the outside..not top or bottom
Steve
Brian
i am confused
am i being thick ?
Steve
Re-reading your past post I think we are both saying the same thing - sorry for the confusion
Brian
Don't get too tied up with where the end grain should be. You need different techniques but at the end of the day you use the wood the way that will best display it's character and suit the purpose intended.
