Shadow10003
New member
I am new to wood turning and have bought a second hand Clarke CWL20RV lathe but although it should have 10 speeds I am only getting speed settings 6,7,and 8 the lever will not move to any other gears
Thanks for the advise I will try this as I know the owner had passed away and the lathe has been idle and in a damp shed for some timeFrom a quick google, it seems to be the same as my axminster m900. If so, it has a variable speed drive based on 2 cones, so the speed can only be changed when running.
If it still will not change even when running, you can take the cover of the belt housing off and see if there are any obstructions. The cones each run along a central shaft, that may have become rusty or need oiling. If you have the back off, obviously make sure you are either only rotating it by hand, or keep your fingers well clear...
I have a Poolewood 28-40 and had the problem with the speed not adjusting, 2 cones as someone else said. I gave it a good cleanup and oil (the first time in about 20 years) and it now works perfectly.I am new to wood turning and have bought a second hand Clarke CWL20RV lathe but although it should have 10 speeds I am only getting speed settings 6,7,and 8 the lever will not move to any other gears
Register today and take advantage of membership benefits.
