Hi Dibs,
I’ve now had a look at the Dehn Lightning Protection guide (a pdf copy is a free download from their website).
In my view you are looking at a stack of costs to protect your property and because it is semi-detached you will have to persuade your neighbour to protect his half as well to the same standard as yours.
Anyway here goes on what is needed as far as I can tell –
A lightning conductor on each gable end of the ridged roof and additional ones at approx 2m intervals along the ridge line. The bonding straps between these particular lightning conductors must be supported OFF the ridge tiles at 1.0m intervals.
A lightning conductor on your assumed shared chimney stack.
A lightning conductor on each of your dormer roofs.
A lightning conductor on your satellite dish and other antenna.
Every lightning conductor needs to be bonded together with strap conductors.
A down conductor on each corner of the property.
These down conductors to be bonded together below ground level (minimum 0.5m depth) all to a continuous ring conductor around the entire property (again minimum 0.5m depth and approx 1.0m away from the property walls).
The down conductors also have to be a certain separation distance away from doors and windows (to help prevent ‘flashover’ into the property).
The only saving grace is that you can use aluminium conductors (70mm2) or hot dipped galvanised steel (50mm2) which should be cheaper than copper or stainless steel). All down conductors have to be protected from corrosion to a length of about 0.3m above and below ground level)
So Dibs after all this what do we have? –
In the UK the probability of a direct lighting strike on a low rise domestic property is very low.
The cost of providing a substantial external lightning protection system for a domestic property is relatively high.
On balance I wouldn’t bother installing such a system on my house but your needs and drivers are different to mine.
However I think it would be worthwhile to install Type 2 SPDs on your 3 phase TNC-S incomer and on your single phase incomer to your house. I’ve assumed the 3 phase supply would be terminated in your workshop (assumed to be detached) and a single phase supply from this then taken into your house. These will protect against surge currents induced in the 3 phase supply by lightning ground strikes (if the supply cable is buried) and against cloud to cloud lightning (if supply cable is overhead on poles) and also power surges on the electricity network.
Similarly you can also install low cost SPDs on your telephone line and satellite dish coax cable preferably before they enter the house.
All SPDs must be installed strictly as per manufacturers recommendations.
If anybody wants to read up on Faraday Cages then Wikipedia has a reasonable description as does
www.Faraday.org.
Dave
