Spackling ?
soapy
24 Jul 2005
Camberley, Surrey
Just got the latest issue of American Woodworker and it has a tip for treating the machined edges of mdf. They recommend using spackling, which as far as I can tell seems to be a Polyfilla type of product. Can anybody be more specific ?.
jasonB
26 Nov 2004
Surrey
I'm sure one of the Americam members will confirm it but polyfilla is just about the same, Spackle ifs the material spackling is the process of applying it. I have also heard that drywall filler (easyfill) will work. I just prime & paint it, no special sealers.
Jason
Scrit
17 Sep 2002
One alternative is to use Drywall Jointing Compound, available pre-mixed from places like Wickes. Spread it on thinly with a finger and leave to dry overnight. Sand-off the following day (one of those abrasive nets they use for plaster is best) then go from there. It's rather like plaster, but much finer. Cheap, too.
Scrit
soapy
24 Jul 2005
Camberley, Surrey
Thanks for the replies, I usually just paint with a rub down between coats. I have also used emulsion paint with around 10% of pva mixed in for the 1st coat which works pretty good.
Regards Soapy
