Spaced out Apple.
KimG
Little Woodworm
2 Jul 2012
Pembs
I roughed this bowl out in May, it was pretty straightforward despite the knots, however, once dry it was a different story, the outside was OK, but the inside was hard as iron and very prone to making the gouge snatch and difficult to control, hence I ended up using a carbide scraper to finish off shaping the interior curve, naturally this resulted in a mishap (how unusual!) and an unpleasant pair of cracks appeared from the rim down through what is now the red coloured section, however, by judicious use of CA glue and liberal coats of lacquer cut back I was able to effect a repair that is as good as invisible, what luck!
The natural edge looks a little strange, this is because it isn't trully natural, the section above the red bit was in fact sawn by the logger, so I had to do a little shaping, also the bark was extremely fibrous which meant I had to dispense with much of it as it steadfastly refused to tidy up, being utterly determined to look as hairy as possible.
The feathered section I have coloured Yellow combined with the overall scheme looks very like an idealised comet in the night sky, so I will likely market the bowl with that as a theme.
Comments etc welcome!
The colour is Chestnuts spirit stain and cellulose lacquer cut with buffing compound and polished on the 3 wheel system.
Wow - that's well shiny! You'd never know it started off as a nasty hard piece of splitty apple. Lovely piece, well done.
I've been very disappointed with most apple wood I've tried. Kiln dried blanks are hard and nasty to turn and mine had little figure. Logs I've attempted to dry myself have usually been unsuccessful - even those that managed not to split ended up with hidden defects inside (splits, cracks and wormholes :-( ). Green turned pieces (lovely wood to turn when green) were also disappointing - ending up with split in them. Apple does make lovely decorative dowels, however!
Fantastic finish you got there. I got some powder dyes from Keda dyes that I am going to give a try when i get a chance. They market them as the strongest dyes available so we will see. I am new to all this so not expecting anything near what you have achieved. Still part of the fun is in learning how to do things.
Keep up the good work
Well that's Some Shine and some piece you nailed that one I sincerely take my hat of to you =D> =D> =D> =D> =D> =D> =D> =D> =D> thank you for showing such quality Put my Staining in the shade but im uising the mylands kit I got from Yandles ill be going there this weekend for another demo If Mr Raby is there if its the other guy ill give it a miss
Regards
Bill
