Soundproofing a roof
Chris Knight
14 Jan 2004
SE London - NW Kent
We have a flat roofed bedroom in our house that has leaked in the past in heavy rain and although now re-felted and waterproof for the last five years carries the sound of the rain all too clearly - enough to wake a light sleeper.
Bearing in mind the likelihood of the possibility of further leaks as the roof ages and also the desirability of reducing the noise level in heavy rain, I am looking for suggestions. At one extreme, assuming planning permission were forthcoming, we could probably have a pitched hip roof constructed, that ties into the main pitched roof but something cheaper/simpler would be good.
Grateful for any ideas!
cornucopia
21 Jul 2008
Leicestershire
from what i understand of sound proofing you create a room within a room without any solid fixings from one to the other!!!! a bit hard to do with a ceiling!!
but from what I know you could improve the situation by a couple of methods
1. screw some 1/2" battens up over the existing internal ceiling and board it out with 1/2" plasterboard then either cross line and paper or skim with plaster. If you've got plenty of ceiling height you could increase the size of the batten and fill the void with insulation, the looser the better.
2. glue up/screw up the plaster board with the 1 1/2" polysterne glued to the back of it, then as above dry line or skim.
Paul Chapman
26 Jan 2006
Bookham, Surrey
Hi Chris,
This is a suggestion concerning the felt rather than soundproofing. If you decide to keep the flat roof, next time you have the felt replaced, go for the seamless glass fibre stuff (similar to how Waka had his workshop extension roof done). Much, much better than felt. We have several flat roofs where our bungalow has been extended over the years and I had them replaced with the glass fibre stuff a few years ago. Excellent stuff. Although if you can go for a pitched roof, that would be even better.
Cheers :wink:
Paul
wizer
3 Mar 2005
Our bedroom is the same and I am a very light sleeper. I do dream ('scuse the pun) of putting a sloping roof on.
Cornacopia's idea is the best I can think of, but you can get sound absorbing plasterboard. Called SoundBloc if memory serves.
I also agree with Paul. My kitchen roof was done like that after years of leaks. No problems for the last 3yrs.
StevieB
29 Apr 2003
Chatteris, Cambridgeshire
Do you have gravel or chippings on the felt? I have seen these added with a bitumen layer to act as a barrier for both wind and rain protection, the wind does not lift the felt edges so badly and the gravel gives an irregular surface to stop rain drops 'splatting' onto a flat one. Not sure about level of noise reduction but might be a cheap option to try.
Steve.
Paul Chapman
26 Jan 2006
Bookham, Surrey
In my experience, the application of gravel doesn't do much good. In fact it tends to give you another problem, in that you spend hours up a ladder cleaning gravel out of your gutters and drain pipes :(
Cheers :wink:
Paul
Shadowfax
1 Nov 2003
East Sussex
I definitely would not recommend using polystyrene sheet in that situation. Purely from the fire hazard point of view. I am sure it would deaden the sound, though. However, there are better insulation boards than the dreaded expanded polystyrene!
SF
big soft moose
22 May 2008
assuming you have the head space , batten round the walls and put a hanging ceiling in support on these with acoustic insulation on the upward side - easy in a small room , next to impossible in a big one
Chris Knight
14 Jan 2004
SE London - NW Kent
Thanks for your input guys - seems rather similar to my rough thinking about possibilities. I was interested in your comment on the fibreglass Paul and if we stay with a flat roof, I shall do that. However, on balance I think I will try for a pitched roof. It will probably look better from the outside and won't involve sacrificing headroom inside.
Philly
24 Nov 2003
Dorset, England.
Chris
I have used Rockwool slabs under a plasterboard skin to soundproof (wrong term really - reduce the transferred sound) walls. Makes a significant difference, especially in the mid to high frequency range.
Pretty cheap, easy to do - you only lose around 75mm from the ceiling.
Hope this helps
Philly :D
OLD
9 Aug 2004
Nantwich Cheshire
Just confirming the above my workshop flat roof uses
ply to the top then three layer felt .
you can just hear thunder storm rain but any other is quiet
markymark12
7 Sep 2007
South
Hi
Something i have installed a fair few times is RB1 resilient bar, sounds fancy but cheap as chips, loss of headroom !.5", screw it up counter to the ceiling joists, and overboard by attaching to the flap of the metal, it makes for a cheap fix which whilst not being perfect will make a worthwhile difference. A screwgun is a must, with a depth setting nose.
Have fun
Mark
Chris Knight
14 Jan 2004
SE London - NW Kent
Hmm.. thanks everybody for the further input - I am now planning to get an estimate for a pitched roof with the insulating option as a fall back in case the pitched roof works out too expensive.
jasonB
26 Nov 2004
Surrey
The alternative to a pitched roof is to just increase the fall on your existing roof, not sure what the span is but just a 50-100mm increase will ensure there is no likelyhood of water pooling on the roof.
This can be done by simply adding extra furrings and while the deck is off add sound insulation batts between the joists. If you don't alter the roof from the outside then its worth ripping the existing ceiling down and adding the insulation from below.
Jason
