for about thirty years. Put drawbars on my Jacobs chucks.
I had a slight problem - the MT2 arbors are threaded 10mm, which is too large a threaded rod to go through the tailstock. I ordered some helicoil type inserts, but found that a 10mm insert is in fact 12mm - they obviously rate them by the thread size the fits into them, rather than the size they fit in to. I couldn't be bothered to send them back - the P&P probably wasn't worth it, so I ordered a set, thus guaranteeing I'll never need one ever again.
The No.32 is a JT2, the No.34 is a JT6. They are easy to pop out - just drill a hole through the bottom of the chuck and put a knockout bar of some description through it. The bottom of the chuck is concave, so the bit drifts to centre. I can't think of the last time I used a Jacobs chuck in the headstock, but I put a longer rod on the smaller chuck just in case. Two washers and wingnuts, job done.
