Solar panels
Roxie
20 Sep 2011
Bedfordshire
Does anyone know anything about "Lightsource". Apparently they are prepared to buy your Solar Panels, giving a lump sum up front, and take on the maintenance and equipment replacement. I presume they will benefit from the "Feed in Tariff" whilst we as householders have the cheap electricity during the day.
I would welcome any feedback.
Thank you
Seriously stay away from these stupid schemes, you are signing a deal with a devil over a stuff where you will barely brake even (if that...) because of the stupid prices they are seling those panels/installation to you. They make their money from Selling you the panels/installation ( on credit paid via feed-in tariff -that is if nothing changes for at least the next 10years ) they make squat from the actual energy produced, It's all about selling you the stuff...
If you really want solar system, buy the loose panels yourself ( they are NOT at all expensive nowadays) and install it yourself,
although you aren't living in Spain, are you?
Big of them to take on the maintenance and equipment replacement as in my experience there isn't any. Got two systems on the farm and both over 5 years old and nothing goes wrong with them.
I used to work as engineering director of a solar energy firm, in this case concentrated PV but I learned a lot about silicon panels also.
First, if you want the feed-in tariff the panels have to be installed by a government-accredited supplier.
Second, they do not last for ever. The panels themselves are guaranteed (usually) for 25 years, and their lifetime is probably about 30. It's limited by diffusion across the p-n junctions (the thing that makes them work). Cool climates are better for lifetime so the UK may be OK in that regard. My main worry is actually of young vandals with stones. And they do need occasional cleaning.
But nobody knows how to make an inverter that lasts that long. 5-10 years life and a 5 year guarantee is normal. This of course is the part of the system that converts the DC generated by the panels to AC, and feeds it into your house or the grid.
My own choice was not to buy the panels but to lease the space on my roof to a company that did the installation and will do all the above maintenance. They get the feed-in tariff and I get the electricity in the daytime (4 kW peak though usually a good bit less). And am about to have air-source heat pump central heating installed, which will give still more benefit. Those I am buying, and they will be paid for over a few years by the RHI scheme.
Keith
I assume you are talking about an existing installation. We've had loads of cold calls about our panels - it seems likely that there has been a leak or security breach of the data about existing systems.
Have a look at http://www.microgenerationcertification ... p-with-mcs
I would not consider any of these 'schemes' - remember that if it sounds too good to be true then it most likely is. These schemes are not being offered for your benefit but to make money for someone else!
Misterfish
Thank you MisterFish. I have looked at the link and have made a reply. As you say "too good to be true".
