I have a Sehppach HMO solo planer and I did as you all advised me to set the blades which I have done from ¼” to 1/8” then to 1mm but I still get snipe very bad. (useing just the planer its perfect) Then I removed the in feed table and tried to get the out feed roller ( On thicknesses) to move down as it’s a good 1/8” higher than the blades and it should be level ( So the net tells me) but to no avail, it’s as far down as it will go I then built a flat plywood plank no good, so I built better one dead level snipe, and raised slightly still I get snipe only on the end not on the front, Just don’t know what to do next. Any comments would be appreciated. Thank you
