My woodworking had evolved from being hand-tools only, to also involving milling (and occasionally harvesting) my own timber this is posing me a problem in terms of the available thicknesses... I've been getting a local company to re-saw boards for me (mainly 11*300 sawn ex 25, and 38*350/11*350 sawn ex 50), but it's time consuming cutting to appropriate lengths for transport, taking it to them, and collecting it...
So I started thinking about what options I had in terms of a compact, semi-portable piece of equipment capable of deep-ripping:
That thought process has me looking for a saw with a high power to size ratio, ideally capable of taking a riser and with wheels suitable for a wider blade (1" is probably more than I could expect). Being light enough to sit on casters would be an advantage.
Does such a thing exist, are there other compromise solutions I could think about or should I just suck it up and hope one day I'll have the space to house a nice old Robinson!
Edit: I have thought about this in the context of Matthias Wandel's wooden bandsaw; it doesn't look overly complicated, just requires a very high standard of execution. It certainly seems that it would be a viable option in cost terms, but would be a major project itself; It's quite literally the only way I can imagine being able to get a compact saw with a powerful motor and proper (+4") resaw blade.
- Table-saws are right out... the only ones suitable for such deep cuts are massive static cast-iron monsters.
- Bandsaws optimized for this kind of cut are still large static machines.
- Clearly I'm not going to be able to saw 350mm wide boards, but the wider a board can cut, the more useful a tool I'd have
- To some extent double full height fences and a low feed speed could eak out a little extra width from a small bandsaw
- the greater the blade width the saw could accept, the more suited to resawing it would be
