Smallest half inch 1/2" router?
jimmer
a right member
11 May 2016
Ardeche, France
so far i've found the triton one: Triton 925837, 1010W and looks quite andy, speshly at 150 quid, or a similarly sized blue bosch at more like 400
anything else i could consider?
i already have a ig makita and a bosch mini router. i'd like a 'midi size so i caa leave the big one in the table and so i't a it less weighty
what you got?
But the. grammer and punctuation And Bad spellin, do gets boreng afer a wile.
The question is, what do you want to use the router for?
1/2" gives less vibration (the shaft is more rigid), and can be driven harder, but that suggests a more powerful motor is helpful. So a low-powered 1/2" router is a bit counter-intuitive.
Have you considered using an 8mm collet in a smaller router? They are a decent step up from 1/4", so might be what you are looking for, and most decent 1/4" units will also take 8mm (my old & small Bosch ones will, for example). It's a very inexpensive way to improve their performance...
They don't teach English like they used to, do they? :roll:
Another texter in our midst.
Welcome by the way, remember most of us are old and do not understand text speak.
OKM8?
MikeJhn":55rhi236 said:
Draper Expert: draper-expert-1350w-230v-combination-router-kit-t42255-15.html impressed enough that I bought another.
The Draper I linked to above, I bought due to having low level double handles on the fixed depth accessory, I wanted stability beyond everything else due to Arthritis in my hands, it worked exceptionally well, so I bought the second one, its a lot smaller than most 1/2" routers and has never stalled or given up no matter what I asked it to do.
