custard
Does anyone know of a good quality small circle jig (35-70mm radius) that is directly compatible with a Festool 1010 or 1400? Something similar to the American Jasper type circle jigs would be ideal, where it can be re-set to make identical sized circles?
http://jaspertools.com/products/#pagecontent
Some of the circles will be in 10mm thick material, and if it was just for this I'd cobble something together myself with a guide pin in a false MDF base plate, but some will be in 40mm thick hardwoods and may also require a second pass with a profiled cutter, so I think it needs something quite beefy like the polycarbonate Jasper Pro range to handle it.
