Slowing down bandsaw gumming
RichardG
If at first you don’t succeed have a cup of tea.
29 Mar 2018
South Norfolk
I've been cutting up some green Ash and I've never known such bad gumming up of the bandsaw blade, tyres and guides. After a cutting a single log I'm having to scrape the blade, scrape and clean the tyres and then remove and clean the guide bearings. I've had a search on here and elsewhere and seen people adding all sorts onto the blade, carnauba wax, silicone (no way), oil, wd40 etc. but I'm not sure I can bring myself to risk contamination of the tyres?
Just wanted to get the latest thoughts on this? What about using some spring steel and making a blade scraper to keep it clean? My last bandsaw had the older design block guides which I think actually kept the blade cleaner by acting as scrapers than the more modern bearing style?
I had a similar problem when cutting green timber into planks and while scraping helped it doesn't clear the teeth. What helped me was I took the saw off, folded up and dunked in hot soapy water for a 5 minutes. This soaked most gunk off and a stiff brush got the rest. Dry and put back on and Robert is your mother's brother. Laborious but it works.
