• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Found Sliding table for 01332 saw
Sorted, went for the Axminster as on physical inspection the sip one was less than impressive, picked it up for a fair used price, just need to mod my saw now to fit
Nice , would be interested in seeing how you attach it to the saw
the plan is to just drill the body & attach, i have the approx measurements from the Axminster saw & there is just enough room on the SIP/Itech body for the backing plates (just need to move a switch wire)
somone has done it before with the sip 01332 so i took the gamble
only thing i dont like is that its a pain to keep taking the cross cut fence off when i need more cutting room, its rather annoying, I'm deciding how to mod it to make things work better.
Ah brilliant , just a few (ish) questions if I may
How does it attach the the saw - i have the SIP 01332 saw
So you prefer it against say a mitre gauge or sled
roughly what size is the track and how far does the sliding table protrude past the saw , just seeing if I have enough room or can move items around to accommodate it
And lastly how much did you pay for it as I found one locally to me
PM me if you wish
Graham
PM me if you wish
Graham
No problem
i had to drill holes for the mounting brackets as this is designed to fit the axminster version theirs is pre drilled, the 01332 isn't, i also had to move one switch wire that runs down the inside frame which was right where a hole needed to be, but that was a simple job... once you have the holes in 2 flat plates sit inside the saw frame & you bolt through the holes into them.
certainly prefer it to a simple mitre gauge, never had a sled as the only cross cutting i tend to do would be on items too big for most sleds....
i will measure the track for you tomorrow, it can be adjusted so it can protrude varying amounts from the front or back, mines currently set at 50/50.
i think i paid £200-250, but i honestly cant remember for sure
No problem
Brilliant thanks very much most appreciated
