paul24dual
Can anyone recommend a sliding mitre saw under £100!!?
cheers
cheers
paul24dual":qvuupheo said:Can anyone recommend a sliding mitre saw under £100!!?
cheers
JJ1":3lza4hze said:Can anyone recommend a sliding mitre saw under £100!!?
Lidl had one for £49.99 a couple of weeks ago. Might be worth ringing around a few branches to see if they have any stock left. I've bought several of their power tools over the last year or so and for the money they cost and the fact that they're covered by a three year guarantee, they're not bad at all and work just fine for DIY use.
Screwfix often have some of the Evolution machines for under £100. I've not used one personally but I'm sure they'll be fine for diy use as long as you don't expect too much from them. The thing that puts me off them is the fact that their blades don't have a standard bore size, meaning you can't buy a decent, fine cut blade from a decent blade manufacturer, at least not in my limited searching but I stand to be corrected. But, I guess that's not what their designed for, more as a rough cutting, cut anything type of saw.
JJ1":3nc0lnwb said:Screwfix often have some of the Evolution machines for under £100. I've not used one personally but I'm sure they'll be fine for diy use as long as you don't expect too much from them. The thing that puts me off them is the fact that their blades don't have a standard bore size, meaning you can't buy a decent, fine cut blade from a decent blade manufacturer, at least not in my limited searching but I stand to be corrected. But, I guess that's not what their designed for, more as a rough cutting, cut anything type of saw.
wizard":n3vzegrq said:Screwfix remove most of their bad reviews, i have seen them disappear
wizard":6yg9n92f said:Screwfix remove most of their bad reviews, i have seen them disappear
carlb40":2s9vnrvt said:I wouldn't buy tools on the recommendation of one book. There are plenty of ways to cross cut timbers without a mitre saw. Personally i would stick with a few better quality tools and get the most out of them.
You have a circular saw, so with a few jigs etc that will do everything the mitre saw can do. IMO you would be better off leaving the mitre saw, unless you have a load of skirting/ architraves to cut? Then save up for a decent small bandsaw/ table saw. For around £250 you could get a used kity 613 and that would be much better suited to furniture making.
paul24dual":3px1e3ww said:carlb40":3px1e3ww said:I wouldn't buy tools on the recommendation of one book. There are plenty of ways to cross cut timbers without a mitre saw. Personally i would stick with a few better quality tools and get the most out of them.
At the moment i have a scroll saw (for cutting out shapes like hearts, fishes etc!!, ornamental stuff for the house!) and a circular saw (for cross cutting & ripping). Would i be better off in the future investing in a bandsaw and can i use that for both applications? It would have to be a benchtop bandsaw because of the space!)
