JimD
Hi all,
I’m looking to buy a mitre saw that will be fixed to a workshop bench that is up against a wall.
The bench is just over 2’ deep and I don’t really want the saw hanging off the front too much as I will be walking past it a lot and will no doubt bash into it every time.
Ideally I was looking at something like the Dewalt DW717 or Makita LS1016L as both are pretty good bits of kit with 10” blades and sliders that allow 80mm thick and 300mm cross cuts. However, I don’t think these will fit on the bench as the slide poles will stick too far out of the back and hit the wall. The dimensions quoted online for the Dewalt state a depth of 541mm and length of 718mm but I cant believe the front to back depth is that shallow when in use.
I will have a table saw so a huge cross cut width isn’t essential, but it would be nice not to have to drag the table out every time I want to cut something wider than 4”.
So, with my bench depth limitations is a sliding mitre table a no go and should I be looking for a fixed saw instead with a half way decent cutting width/depth. If so do any recommendations spring to mind? Budget is £500 ish, but happy to spend less
Any input appreciated....
