- Joined
- 19 Mar 2007
- Messages
- 5,300
- Reaction score
- 431
Everyone talks about using the skew and using the bottom 1/3 of the short point, which I have always called the heel. Also I have always called the long point the toe..
I use the toe and the 1/3 section leading to the toe as much as I do the heel. Especially if I am turning a parallel shaft. I find it so much more acurate to have the handle at the much reduced angle to the work using the toe and keeping the cutting angle than using the heel and the skew is at about 60º to the work. Sorry, not a very good explanation.
I also find it easier to do balls this way, using the toe. Especially small balls.
What is the general thoughts on this?
