hunggaur
Hi folks I have a sip table saw with has always been fine
However over recent weeks it has developed a problem
When you angle the blade to the right it is fine and you cen get it down you abut 43 degrees no problems
Then with the last 3/4 turn of the angle wheel the far side of the blade starts to twist towards the right of the table so when you ar down to 45 degrees the far end of the blade is catching the right side of the removable steel table access plate.
The front edge of the blade is still about 2 / 3mm clear of the blade access panel
Any one else experienced this problem and could give me any insights
Jon
Jon
