SIP dovetail jig
hasbeen
21 Jan 2003
mid - Cornwall
Greetings
Is anyone actually producing joints with this bit of kit yet?
I ordered a 12.7mm bearing guided cutter from Trend, and guess what.... I got 1/2" sockets and 3/4" tails!!
Presumably, I should have ordered the "other cutter", the 14.(something)mm one:
Can anyone confirm the tip size of the right cutter? I'd be eternally grateful
kityuser
12 Jan 2003
i have managed to successfully produce dovetails.
from page 154 fo theTrend 2002 catalogue, you want C162 (@ £10.80 +vat)
but I actually ordered my cutter from axminster,
" P217011 PERFORM P217011A 1/4" SHANK DOVETAIL CUTTER FOR AP"
at
http://www.axminster.co.uk/default.asp?part=DTJ
its exactly the same, but cheaper.
TIP : make sure that the grub (the the bearing collar) screw is done up tight before you start up the router!!!!
I did`nt and the grub screw shot across the workshop @ 100MPH never to be seen again!!!
hasbeen
21 Jan 2003
mid - Cornwall
Hi Steve
Thanks for the info
Nasty, that! Could have shot up yer nostril: :shock: I wouldn't fancy having to explain that at A&E!
kityuser
12 Jan 2003
your welcome.
I know!! its tiny as well (1.5 or 2 mm i think)
when you get it going, I`d like to hear what you think if the SIP jig.
I managed to get some fairly nice joint out of it last weekend, a good tip is to print the manual from the axminster site (for their jig).
