SIP 01332 Table Saw Restoration
AndrewR86
7 Oct 2018
Antrim
Hi guys,
After a year of searching for a table saw I got my hands on a second hand SIP 01332 table saw for £300.
Apart from the height adjustment not working and rust on the table top it’s in decent condition. Hoping someone on here can help me with a few queries...
Has anyone recently cleaned up a cast iron table top? If so, what products and process did you use? It looks like surface rust only.
The height adjustment has broken. On inspecting it there is a weld broken that would hold the threaded bar in place and tension the adjustment setup. I can re-weld it but I’m trying to work out if the weld is supposed to be there or if someone has put this as a fix. Does anyone know what way it is supposed to be.
Thanks in advance!
Ttrees
Iroko loco!
18 Nov 2012
In me workshop
I would give it a wire brush to see if the weld has a bronze look to it.
Ditto with the table.
You can buy "all weld" rods for the job
Tom
