Quantcast
Single skin garage window lintel
Lazurus
22 Sep 2017
Norfolk Broads
My garage has a simple wooden frame window in need of replacement with a upvc unit. Currently there is no lintel and 2 x brick courses to the roof. Is it a (competant) DIY`ers task to retro fit a lintel? If so which tyrpe?
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
Usually a concrete lintel is used on single skin brickwork if it’s only 2 courses I’d remove both courses & replace them with a 140 deep lintel such as this
You just need to prop up the roof rafters that sit on the brick work to be removed, take out the bricks & put the lintel in their place mortaring the lintel to the brickwork 150mm past the window reveals & level with the existing brickwork. Once set remove the props.
Lazurus
22 Sep 2017
Norfolk Broads
Excellent - thank you
