Cheshirechappie
Paul Sellers shows how to use a nail as a substitute for a drill bit - a very simple and elegant dodge, I think!
https://www.youtube.com/watch?v=HCCiz9SwJhc
NazNomad":3n9j2i6p said:However, if he'd blunted the point of the nail before driving it in, it probably wouldn't have split the wood.
A sharp point on a nail will force the wood fibres apart... a blunt point won't (as much).
Bradawl is highly effective in its right place.Cheshirechappie":1findczq said:I suppose the four-facet 'sharpening' leaves the nail acting rather like a bird-cage awl, but one sized to the brad going through it. The 'blunt ended' nail technique is closer to the true bradawl - the one with a tip like a sharpened screwdriver - and acts on the wood fibres in a similar way. Nice to have a way to make the 'tool' fit the job in hand exactly, though.
Come to think of it, the bradawl is about as fashionable as flared trousers, these days. Is it really so ineffective a tool compared to a hand drill (or battery drill) and small twist bits?
Pete Maddex":13ydm43j said:I used a cut off leg of a paper clip about a week ago to drill a hole, the flattened end from the top side of the cutters gives a clearance so the wire doesn't get stuck.
Dunno it's hardly complicated spending another few seconds sharpening the nail end. Also you want a precise position for the hole if you are working with thin stuff or small hinges etc, so a point does have a point.bugbear":qjnatqfq said:Pete Maddex":qjnatqfq said:I used a cut off leg of a paper clip about a week ago to drill a hole, the flattened end from the top side of the cutters gives a clearance so the wire doesn't get stuck.
This.
Sellers seems to be over complicating a standard, simple process. Old books speak of simply
clipping the head off the nail, and inserting the nail in the chuck pointy end first, with
the clipped end protruding.
The clipping action makes a crude cutting edge, and also (very slightly)
make the cutter wider than the shank, leading to an effective drill.
Made in 2 seconds flat. Try it!
BugBear
I think we're drifting off topic; this isn't about making general purpose "proper" drills; it's aboutPete Maddex":19468051 said:Use a hinge drill to centre the hole, pop one screw in, hardly complicated.
Pete Maddex":1dpk7208 said:Use a hinge drill to centre the hole, pop one screw in, hardly complicated.
Jacob":3kpd5iqg said:Brilliant! I've been pre-drilling for pins like that for years (I've made a lot of little boxes) but always scrabbling around for the right drill bit, and losing or breaking them. An 0.5mm twist bit is very tiny and fragile.
That's what is good about Paul S; very practical and sensible
One prob is that many chucks won't grip below 1mm dia or so. One that will is on the cheap Stanley 105 hand drill and it's worth keeping one just in case
bugbear":32jgoiv3 said:Old fretworking manuals have a slightly more elaborate procedure; the nail is hammered
slightly flat, and two flats filed on, making a tiny diamond point drill, similar
to those supplied with spiral screw drivers. e.g. Millers Falls supplied these:
BugBear
