Digizz
Hi,
Need some advice on a simple joint. The joint is the top corner frame - This frame will be hidden inside aquarium cabinet. stock size is 50mm x 40mm (not square due to equipment sizes). I was going to use M+T but if I can get away with something quicker but still strong, will use that instead. Wanted the rail long and across the uprights for extra strength as there is a long opening for cupboard doors at the front which needs maximum strength.
How would you do it?
Also, need some way of fixing frame inside cabinet - was just going to glue to the inside as the side/front/back panels are biscuited together and are very strong (already done this bit). I guess they dont even need that?
