Sikkens Advice
Mikegtr
18 Jun 2020
Morpeth
I am about to re-coat an exterior wooden workshop after 3 years of buying new, now showing signs of wear in the exterior painting--the supplier coated the exterior with Sikkens, but I do not know which type of Sikkens was used. Your advice on which type of Sikkens to use--can you advise? Both undercoat & top coat. Would you sandpaper (rough up) the original finish as in normal painting? Two coats of top coat?
Is there any other make of paint / varnish that you think is more durable than Sikkens?
Look forward to your replies.
