Show me your wedges and shims
Fromey
22 Sep 2010
Frome, Somerset, UK
I'm sure this is a daft topic, but I'm never sure how to make a wedge or shim when I need one. Do you cut them out of some waste wood or pare them off with a chisel or knife? Do you make them as and when you need them and then throw them away or do you keep a collection? Is there a traditional 'set" of shims that have proven to be generically useful or is that a rabbit hole akin to sharpening methods? Is there any "shim lore" out there?
is this the sort of thing your asking about? they come in packs of different thickness's cheap as chips.
adidat
I find that I don't really set out to make them, I just don't throw them away!
All you need to do is leave a cardboard box in a handy position in the workshop, and put any wedge shaped offcut into it. Some of them would have been 'sharpened' by pushing a stick into the bandsaw.
Carry on till it looks like this:
Also, if you cut a lot of dovetails and use a coping saw on the waste, you get a box of useful little wedges:
I have a few other boxes of oddments including some strips of hardboard cut into little pieces, but I don't want to give the impression that my workshop is just a pile of junk!
That jig he uses would be ok if it was guarded.I use a similar jig for fox wedges with a push stick screwed to the back. The blade is covered with a polycarbonate guard and the operator (me) never goes past the blade.....and I use a riving knife and have the blade at the height of the timber I am cutting.
The safety is for his ears, when he screams out as part of his body is cut by the blade causing him to................... well make a loud ear piercing sound. I'am sure you should all know that by now. (hammer)
wabbitpoo":36z005eo said:
He calls that "safely" ? :shock:
What is so bad about it?
If he was using thinner stock it wouldn't be safe sure. And being from the US he doesn't have a riving knife (they will catch up sometime but they've only had 50 years (hammer) ) also reaching across a spinning blade isn't the best idea but it doesn't seem like an accident waiting to happen to me. The last few we're safer.
Have I missed something?
I have a similar jig for wedges. Mine has a lug to hold the wedge to stop it getting thrown by the blade. I also only set the blade height to the depth of the timber. Safe enough for me. :wink:
