I need a good shop vac, I have a small shop, I have a budget of £200 any help or recommendations would be great
Peter
Peter
the problem with shop vacs is they are great at the diametre hose they come with, but as you convert the small hose to a bigger outlet, as well as branching it, they become a bit useless. Im a bit far away from you but if you were closer you could see how quiet the laguna is, its more than enough for the application youre looking for and very quietI was planning on doing similar for the router table one under and one on the fence
Hi thank you, god that brought back memories as a child my father was in the Army and we were stationed at corsham with 26 field artillery i have heard that they loose suction power in the way that you have explainedthe problem with shop vacs is they are great at the diametre hose they come with, but as you convert the small hose to a bigger outlet, as well as branching it, they become a bit useless. Im a bit far away from you but if you were closer you could see how quiet the laguna is, its more than enough for the application youre looking for and very quiet
Vacuum cleaners of all types, including Henrys, often come up on Freegle & Free CycleI need a good shop vac, I have a small shop, I have a budget of £200 any help or recommendations would be great
Peter
This is why the Triton Thicknesser annoys me. It has a long extraction port but they supply a cover that has a tiny outlet on it, 50mm iirc.I did use on a thicknesser for a while and this struggled as that definitely requires bigger diameter chip extraction.
See this thread for an easy to make 100mm dust portThis is why the Triton Thicknesser annoys me. It has a long extraction port but they supply a cover that has a tiny outlet on it, 50mm iirc.
