JMCARPENTRY
New member
Hey new here guys was just wondering if anyone could shed some light on my issue with my bench top sander, it won’t run I can get the belt moving for a few seconds then the fuse will blow on the plug going through them like jelly beans. Had all the motor out and can’t see anything to be a problem and wondered if it could be some sort of contact on a bearing or something causing too much stress on the machine and causing it to blow out or if failing that it’s the motor, and would anyone know of any of these available the only one i can find is $169 and you can buy the new one for less than that
thanks josh!
thanks josh!
