I have a shed which I want to insulate. I’m going to be using insulation board and my frame is 70mm x 35mm. I’ve been told by my brother in law(who’s an architect)that I need a minimum 50mm air gap on the walls which would mean having to extend the frame which I really don’t want to do. So my options are 50mm board 20mm gap,40mm board 30mm gap or 25mm board 45mm gap. Obviously the thicker the board the better insulation but would the small gap cause me problems somewhere down the line. I definitely don’t want to end up with my shed rotting which he has suggested will happen if not done properly. Also he said that I need to ventilate the air gaps somehow from the outside from the top and the bottom. My sheds got so many different sections that I’d end up with vents all over my shed if I was to do this. Any suggestions or help with this would be great
