Selecting wood for 1st Project
Vect
7 Oct 2012
Leicester
I'm about to embark on my first project this weekend - building a bed frame. (Google "Simple bed plans", click the wood gears link, (US) Queen size)
It's a little bit ambitious, but I think I should be able to get the bulk of the work down over 2 weekends.
As the title suggests, I'm a little bamboozeled by the sheer amount of different types of wood available. This bed is for the guest room, so I'm not after any fancy hardwoods, I was expecting to buy some softwood from a builders merchant and be able to crack on, but it seems a bit trickier than that.
I get a good discount at Jewsons as I work for the same parent company, so I'd prefer to get the stuff from there. Their catalogue is not really suited to the uninitiated so I'm not really sure what type of wood I require, or what I have to do with it when I get it home to stop it from warping.
I'm sure the best timber would be some PSE stuff, but it's not available in the sizes I require (eg headboard needs ~225x50mm) so I'd have to go with kiln dried sawn timber which goes up to 225x50. I'm concerned that I don't have the skills to plane it and keep it square, but I guess thats the fun of woodworking. But my main worry is that once I get it home the moisture content will change and it'll warp. Is kiln dried timber stored outside? seems pointless to me, being in the uk, but as I said, I'm no expert.
The other option i suppose is getting PSE timber, buying a bazillion clamps and laminating the stuff together. I'd still have to plane the stuff to smooth it out I imagine, but over all the effort would be less.
What are your thoughts?
V
Hi, V
Wow, you are braver than me I wouldn't even think of something like a queen sized bed as the first project, bed side table may be.
It will take you weeks to hand plane up the sawn timber you need, assuming you have a bench to do it on, start small.
Do you have any machines?
I have a pair of sawhorses and a circular saw. If it's really weeks of planing I may hang fire till I move house and get a garage to put a bench in.
Although if it's just a few days work to prep the wood, I don't mind.
About an hours drive from me then.. I live in Swadlincote
If you get really stuck You are more than welcome to come over to me and we can put the timbers through the Planner/ thickneser but realistically you may be cheaper off(fuel costs) getting sombody more local to you to plane the timbers and help glue up the panels
Roger
Pay someone to plane it for you. A timber yard or someone on this forum with a planer thicknesser will be able to help.
Modify the plans to suit the available timber sizes would be easier surely?
Thats what I tend to do anyway!
