deema
I have a Sedgwick SM4 ii which is really a brilliant machine in my humble opinion except for the way the whole spindle assembly is held in place. Whilst changing cutters I wound down the spindle to the bottom of its travel.....or so I thought. The whole spindle assembly suddenly disappeared as it crashed to the floor.
On investigation I found that a small bolt with a feeble washer had come out of the bottom of the threaded bar that the whole spindle assembly sits upon. This acts as a stop to prevent it falling out. On my machine which was produced in 91 this did not appear to have any form of anti vibration lockng system on it, hence over time it came loose and dropped off.
May I urge all owners to spend 5 minutes to look inside the cabinet of the machine to check that the bolt is in place and tight. Adding thread lock / anti vibration spring washer would be highly recommended.
I'm now faced with trying to source a cheap stepped aluminium belt drive for the motor as mine took the full impact and smashed!
If anyone knows where to source a similar one o the original it old be much appreciated. I'm going to contact Sedgwick to see hw much an original is which I'm sure will be horribly expensive
