deema
The thicknesser table is now mounted, and clocked at either end referenced off the cutter spindle. We are looking for less than 1 thou variance, which is far tighter than any new PT I’ve tested. The thicknesser table on this PT was not aligned with the spindle straight off and was out by approx 12 thou or circa 0.3mm over the 12” length of cut. To correct this we use shims under the table, between it and the column it sits on. In this case we added two 1 thou (25 micron) shims either side of a bolt to ensure it was properly seated. The radius we inserted them in at multiplies how much it tilts the table at either side. We usually use ‘calibrated’ beer cans that we cut up. It’s amazing how accurate beer cans are in wall thickness.
Anyway, after a bit of adjustment (we’ll Sideways got it bang in first time……it’s not the first time he’s done it!)
It’s about 1/2 thou of 12 microns or variance between the two ends……there is a theme starting
Please pardon the dirty bits, they arn’t scratches etc just dirty hands. Sideways had been ‘feeding’ the tables with both Metalguard and liber on machine wax.
