Securing a tracksaw rail to bench dogs
pulleyt
24 May 2014
Nottingham
Many thanks to Peter Millard for his videos and congratulations on his new new bench build - a thing of beauty and would work well in many small workshops.
I have a similar work bench in that I use a home made MFT top with a Benchdogs fence and track saw for a lot of my sheet material dimensioning. I don't have a hinged rail and have relied on the UJK dog rail clips to hold the rail in place. This has been increasingly frustrating as the metal clips are no longer secure in the plastic slides and need constant checking to make sure they haven't become dislodged. Peter had a chat with David Stanton who had a great idea for a more rigid way of holding the rail against the bench dogs.
I don't have any spare rail connectors but I do have a few T-track bolts spare so I had a go at knocking up something similar using some scrap 6mm birch plywood, four 25mm T-track bolts and four wing nuts.
Now I can leave these locked onto the rail when I hang it up out of the way and it is ready to use next time it is needed. Brilliant - thanks again to David and Peter.
I guess it's critical to keep the ply connectors well clear of the rail edge to ensure that the dogs rest against the rail and not the ply. Could easily ruin all your hard work if cuts are not 90 🙂
Very cool though, probably only a matter of time before a metal version of this hits the shops.
Martin
Indeed. Using T-track bolts does introduce a lot more slop than if I'd used some rail track connectors, so I do need to pay attention when tightening the wing nuts to make sure the track rail is hard against the bench dog.
Once tightened I'm confident they will stay in place but half a rail connector would be a better solution.
I've had a pair of the UJK rail clips since they first became available and tend to use them more than the Festool Rail Hinge....
However, due to the regular use, one of the clips became loose in the plastic section that slides into the rail and was constantly pulling apart everytime I lifted or moved the rail. This was after about 6 months of use.
I solved this by a small application of super glue in the hole of the plastic section and having previously abraded the end of the spring clip, I just inserted the clip into the hole and it's been absolutely fine ever since.
Thanks, I'll give that a go as I will still have occasional uses for the UJK clips.
But I'm delighted to have discovered a solution that just drops straight onto the two bench dogs on the worktop in my shed.
@pulleyt Where did you get the T-track bolts please? M6 thread I'm guessing?
Nice to see people being imaginative and a good idea but a rail square will achieve the same results just by using the screw in dogs, 30mm Bevel Adaptors
To make it more rigid you can put the rail square more central on the track rather than at one end.
Screw in ... to what? The square? Pic please?
(and make sure you've the M8 threads, not the M6).
Hi Dave
The square has threaded holes so you can screw the dogs in, then insert the dogs into the 20mm holes in the worktop. I think there are two 6mm threaded holes and two 8mm threaded holes on each side, I will take a look at mine some time and confirm.
The rail square works very well - I used the MFT dogs in my portable bench build - but at the risk of stating the obvious, this is a pocket-money option for the folks that don’t have a rail square. 👍
Hi Dave
Tks @Spectric
I note you have the MK ?? I'll try it, but guessing you lose MFT space doing so?
Dave I have the Mark 2 and use it with Makita tracksaw and rails, It is very handy because you can cut down full sheets outside and then bring them back inside to finish to size using the track and rail square on a worktop with 20mm holes or standalone with the dogs.
Please don't insult those without your deep pockets Peter.
Insulting? You’ll have to explain that to me; I’m simply pointing out that, whilst I agree the rail square option works very well, it does require a Benchdogs or TSO (??) rail square, which is a significant outlay to many - double the price of a commodity MFT top, for example. And the Dave Stanton dog locks can literally be made for pocket-money. 👍👍
I've just made a 3D-printed version of the clip that @petermillard and David Stanton described in Peter's recent video, for the Makita track. Render of the design attached. It has a pair of lugs that engage in the T-track groove in the track, which prevents it rotating, and thus needs only one track screw. Thanks to David for the brilliantly simple idea, and to Peter for bringing it to my attentiuon.
track_clip_2022-mar-01_03-51-22pm-000_customizedview1432532459-png.130668
