RichardG
If at first you don’t succeed have a cup of tea.
Most of the wood I’ve tried to season for turning always seems to get infested with beetle or wood worm. I’ve now started to remove the bark in the hope this will make the wood less attractive to the the little pippers. My wife uses something called environmesh which is a very fine net which she places over her veggies to keep off pests so you don’t have to use any spray. I was thinking that perhaps a tent made of this would effectively seal the wood from any insect attack? My mind wandered further and thought, if I used breathable roofing membrane then it would not only keep the insects out but would also keep the water off as well?
Is this a totally made idea, will the wood just get mouldy instead?
Edit: pippers = b u g g e r s, I’ve been censored
