50020
Hi
I am in the process of building a play centre for the 'kids and I am getting round to to the 'Climbing Wall' part of it.
The width of the wall is ~1600mm and I will probably go 1600-1800mm high. I have bought two 4'x8' sheets of Buffalo Board, and these will need cutting (leaving some significant off cuts!) so I am going to have many open edges on the boards. The boards are on an an outdoor plat centre, so I need to seal the edges to prevent de-lamination or other weather damage.
What should I use to coat the edges to stop the weather penetrating?
I have learned of Smiths Clear Penetrating Epoxy Sealer but this seems crazy expensive, and I am only needing to seal about 16m worth of 18mm edging, so surely wouldn't need 1 litre.
www.makewoodgood.co.uk
Clear Penetrating Epoxy Sealer - Smiths CPES - No 1 for wood
Clear Penetrating Epoxy Sealer, CPES, provides a firm breathable base for top coats on timber. It stops rot and strengthens decayed wood.
