Jacob
What goes around comes around.
Following a recent discussion I had some more idle thoughts on this topic
Anyone who has used a scrub plane knows it removes material fast and easily. That’s what it’s for.
At the same time it also removes material deep which is also what it’s for e.g. removing material from a dirty surface (paint, grit etc) by cutting mostly in the clean wood below (hence the name?).
It also does these things easily which at first glance would seem odd - more material for the same effort, how can this be?
Well the simple answer is that a deeper narrower scoop will remove more material than a wider shallower scoop, for approximately the same effort. The explanation is that effort is roughly proportional to the length of the cutting edge actually engaged and as it approaches a semi circle the volume of removed material is greatest. The scrub blade is heavily cambered, approaching a semi circle.
Hence all those rapid removal cutters such as roughing out gouges, adzes and others, roughly semi circular. It also explains the function of camber in general - faster - more material for the same effort.
It won’t be exactly the same effort of course, as the blade has to wedge itself through the material and prise it up. A scrub plane works along the grain quite well but somewhat faster across, I guess because the uplifting of waste is easiest across the grain.
Another factor with camber is that as it plunges through it also ploughs deep due to the planing angle. This reduces the need for downwards pressure as the plane pulls itself down, whereas fine shavings require more pressure (and a very sharp edge) to keep the blade engaged. One of the first things you notice about using a scrub is how little downwards pressure is need - once it's engaged it zips along anchored into the groove.
