Screw type for Parkinson's 6F engineering vice?
benjaminmiguras
New member
20 Apr 2021
Worcestershire
Hi forgive me if this is in the wrong section but I have a quick question to those with much more experience than myself.
I have a large Parkinson's 6f engineering vice with quick release and it is missing a bolt at the front. I will post a picture up for idea of scale but this missing bolt stops the quick release from working
Any idea what type of bolt I should look for?
Ben
I'm in the process of restoring an 8F so could check the parts on mine. Are you meaning the component that looks like a castle nut? Or maybe the quick release lever?
nice vice/vise -- worth getting it going again -- Parkinson invented this type of buttress thread quick release, copied a few years later by Record, Woden, Fortis and others - many parts are interchangeable but not all, and the no 8 means it's a big 'un. oh, sorry just seen yours is a no6 - still a fine lump of cast iron
I rescued my old Parky with a spring and nut from a cracked Record of about 100 years later - seemed identical, but I may have been lucky.
On my 7-F, there are 2 countersunk screws that hold the front plate on, they are 1/4” 20 tpi. The two I have are 22.2 and 23.5 mm long threaded length.
I ran a Whitworth tap in of that size with no issues.
There are 2x more screws that hold the quick release handle to the slide, and hold the slide-guide to the casting.
The one that holds the slide and handle together is countersunk, 4.4 mm diameter (possibly 3/16” as that is 4.7 mm), 10.4 mm threaded length.
The one that holds the slide-guide to the casting is 20 tpi 1/4” again, dome head, with 13.3 mm threaded section.
