Screw drivers
AndyBoyd
22 Nov 2002
Heiloo The Netherlands
I'm in the process of designing a new workbench and a second tool cabinet.
The cabinet will be for general tools (spanners, screwdrivers, allen keys etc etc)
Upon noticing the Lie Nielsen screwdriver I was wondering does anyone know a retailer of high quality screw driver handles that can take the 1/4" hex bits. Wooden would be ideal but not so necessary. One thing I like is the sprung ball bearing fitting ones that the longer bits fit into, negating the need for a magnet. Also one with a long shaft and one with a short shaft like the LN one:
http://www.lie-nielsen.com/tool.html?id=Multi-Tip
Andy,
I am unclear what you are after. Mutli-tip screwdrivers are ten a penny - mostly plastic and very cheap. If you want high quality, what's wrong with the LN? For length, surely its the bit not the handle that is the important thing?
I do like the LN but it's 45$ so a bit pricey and even so I'd like one with a longer shaft as well as one with a shorter one like the LN.
I do not want to have to add shaft extenders.
I can get cheap ones but they all seem to fail to bits pretty quick, especially if you drop them as i have just done so.
I'm building up a very good collection of high quality tools and so hanging my red and rubber plasticcy one there will look a little out of place.
Perhaps you could remove the handle of your present one and stick it in a wooden handle? If need be use an angle grinder to get it down to a size and shape you can wrap in a piece of wood (two halves, morticed for the former plastic thing)
